Racor Filter
twofing
anybody know what is recomended (model #) for a 2005 f150 4 stroke outboard.....?<br /><br />Thank you
bossee
Re: Racor Filter
Hi,<br />Go to Yamaha Outboard Motors, US website.<br />Select Your outboard and then Accessories for it.<br /> http://www.yamaha-motor.com/accessories/acsubcontaineritems/8/16/410/5/1709/9223/All/1.aspx <br /><br />These Yamaha water/fuel separators are made by Racor. I have a Yamaha fuel/water separator (the "deluxe" model with clear bowl but without the water sensor probe) myself and they are exactly like Racor. If 60 GPH separator is enough or if you need the 90 GPH on Your F150 I do not know. Check in Your Owner's Manual if You find what is required or just phone a Yamaha outboard dealer.<br />(I have a Yamaha F115.)
bigbrownbuku
Re: Racor Filter
yamaha has a new hard on for 10 micron filters.<br />of course all the filters they put on the engine are 40 micron. if you do use 10 micron make sure to vacuum test after the install. excess fuel system vacuum will hurt your performance.
