steam_mill
- Joined
- Jan 16, 2002
- 413
Boat has a 2003 90hp Mercury. Purchased brand new by me. Maybe 200 hours on it. Boat was also new. I have one single battery on the boat. Also from 2003.
Boat starts and runs fine. Good cranking. No issues with motor at all. Never have to charge the battery get's enough charge from use.
I used to have a basic Aquatronics am/fm cassette stereo. One 12v feed to the radio. Never used the cassette. While underway, radio used to cut out. Figured it was the radio station.
Now:
Installed a Dual am/fm/CD radio. Has two 12v feeds, one for power, another for turning it on. Installed a toggle switch off the fuse panel to run the power on. Chose not to use ignition so I can listen to the radio when floating without having power to the guages.
Radio runs fine when not underway. Never cuts out. When underway, it cuts out briefly like I flipped the toggle switch briefly. Seems to happen more at higher RPM.
I'm getting no interference. Had I not been playing a CD, I would have though that it was the radio station coming in and out.
Any ideas why it is cutting out?
Tx.
My amp gauge is always around 12-13 volts. Only drops when I trim at idle. Radio does not cut out.
Wiring is tight and if I move the wiring by hand, radio does not cut out. Radio does not loose clock or radio station settings (therefore power 12V is fine).
Now:
Tx.
