radio niose
-JR-
Only when my engine is running i get a high pitch background noise in my radio....how do I get rid of it ?
used to have an old car back in the 70s that did this ,thought i but in a condenser somewhere .
fhhuber
You need resistor plugs. Change for the same number plugs but with an R added usually in the middle. Such as CJ-77 becomes CJR-77 (I made those numbers up...) Sometimes they append the R, then it would change from CJ-77 to CJ-77R
That cures it MOST of the time.
Silvertip
Here are some NGK resistor plug designations (not necessarily for your engine however):
BCPR7ES, PFR7H - 10, BCPR6E.
If your boat is powered by an I/O, then the noise may be caused by the alternator. In that case a noise suppressor can be installed in the positive lead to the radio. Ignition noise is more like a lower frequency "popping" noise.
bruceb58
Sounds like an alternator whine. Pull the belt off the alternator and run it for a few seconds to see if it does the same thing.
A bad alternator with a blown diode can cause this.
BTW, some outboards also have alternators.
-JR-
I do have the resistor plugs ,and I have tried a new alternator as the sound does disappear when I unplug the Alternator.
Still making the noise
sam am I
As quick diagnostic, you could open/disconnect the current power and ground wires from the back of the radio and temporary re-power the radio by splicing in and running both a new power and ground wires (could use an extension cord) back into the radio's power in connector/wires, DIRECTLY then powering the wires then to the battery's (assume you have a single battery boat?) pos and neg posts..........Fire up the motor, what happens?
