Re: raising deck
Okay, just keep in mind what I said about stability. It does matter, even for raising that 7x7 section.
The simplest way (and strongest) that I can think of to attach the deck to the hull sides is with a strong glass joint. Draw out the level of the new deck on the sides using string lines or similar.
Glue a cleat to the hull sides at the level of the line using thickened epoxy as glue. You'll probably want to bevel the side that's meeting the hull to get the top level, but it doesn't need to be perfect. Cleats are basically 1x1 wood poles or similar.
Create supports for the deck across the space.. stringer extensions and frame extensions, so the deck has support every couple feet for 1/2 inch ply and closer for thinner ply. You can space the support a bit farther apart if you glass the deck both sides or use 3/4" ply, or use stiffening beams on the deck bottom.
I'd use cleats on the top edges of the frames and stringers that meet the underside of the deck too. More space for glue to adhere.
Then you put glue on top of the cleats and glue the deck sections down in place. Use more glue to form a fillet between hull side and deck top, and glass the joint using two layers of 6 inch wide tape of 12 oz or heavier glass. No screws needed. Weight the whole deck down until it's cured. Sand bumps down.
Glass the whole deck with a layer of fabric or mat after that. Overlap the tape. Then fill or sand as desired and paint or carpet.
This will give you a one piece deck and hull in that area, which will be a lot stronger than the original deck was, and stronger than just using beams or 2x4 pieces to support a deck span.
Erik
