AguaSki
- Joined
- Jul 4, 2005
- 545
I have a 1978 Johnson 140 hp on 18 foot Glastron SSV-188. My RPMs at WOT are about 5,300. I would like to get to at least 5,500 RPMs, and possibly higher. My prop is a SS 14.25 X 15 Rapture. Top GPS verified speed is 38 mph.<br /><br />I am considering raising my motor. Currently the AV plate seems about even with the bottom of the boat, possibly slightly below the bottom of the boat. I still familiarizing myself with boats so I have some questions.<br /><br />Without special equipment, can I use the boat trailer to raise the motor? I am thinking I can lower the front of the trailer, block the skeg, remove the top bolts and loosen the bottom bolts. As the front of the trailer is raised, the transom will drop. I will only raise the motor by one hole. Will this work? Is it safe? What could go wrong?<br /><br />The bolts looks to have some type of silicon around them. I assume I will need to replace the silicon. Do I also need to do anything to the hole inside the transom?<br /><br />I will only raise one hole at a time. Is there a rule of thumb used to determine how much additional RMP is gained per each hole?<br /><br />Any additional hints on doing this?
