ppcshooter
- Joined
- May 15, 2006
- 5
Hi all, <br />New to the forum hope this is in the right place.<br /><br />I have a 87 Sportcraft 22 walk around with a 91 200 Johnson with a small problem. The boat gets up on plane good with no issues but the bow will flatten out when up to speed. I can trim the motor out to get it on top of the water within max RPM range but it just before the prop blows out. This makes also make the prop blow on the turns. The motor is really trimmed to the max, what can I do to? Motor height appears to be correct. It does not seem that trim tabs will help. Bow needs to go up not down. Will a hydrofoil work?
