What do you guys think about using plywood (no metal reinforcement) to raise my transom ~3.5 in.? I am thinking about replacing the plywood backing on each side of the transom with 1/2" plywood and having it extend 3.5" above the current transom then sandwiching more sheets of plywood in between and bolting everything down good.
Does anyone see a problem with this, remember its only a 25 and more than half of the plywood will be below the top of the inside of the transom and a lot more on the outside
