I just replaced the u-joints, raw water pump and thermostat in my '87 Baja. Well, apparently when I removed or re-installed the vertical drive, the water hose that goes between the pivot housing and gimbal housing fell off. I started the engine and let it run for a few minutes in my driveway before I realized it wasn't getting water. There was a little bit of white smoke coming from the exhaust before I got it shut down. I was able to get the hose reconnected (what a pain!), fire the engine back up and everything seemed fine. Do you think I did any damage? The engine is running fine, temp is good and no more smoke. But is there anything I should check to make sure I didn't roast it?
I also have another stupid question. There is a stream of water coming from the middle of the prop (exhaust). That's normal, right? I'm still a rookie when it comes to boats, but I'm assuming it's the cooling water from the manifolds. Please correct me if I'm wrong.
