jlinder
- Joined
- Jul 5, 2004
- 1,086
I pulled the boat out for the season and started prepping it for a trip out on the lake. Started up fine and ran it for about 10 minutes - no problems.
Then engine died and would not restart.
Pulled the gas-water separator to look for water. No water, but lots of crud in there. Going out to get a new one but for now flushed out and filled with gas and put back on.
Engine ran for about 30 seconds to a minute then died again. Removed separator and empty again.
I read the FAQ from Don S. (thanks Don) on this and am going out to pickup what I need to run the tests suggested but thought I would post a question here to see if someone has any ideas.
Specifics: 1988 OMC drive w/ 5.0L GM engine
My thoughts:
1. Separator/filter needs to be replaced. Getting one now.
2. Where did all the crud come from? Suspect problem/dirt in the tank.
3. Believe the fuel pump is working since the fuel is being sucked out of the separator and fed to the carb.
4. Believe problem is between the separator and the tank. Wonder if there is a clog somewhere in the line from the separator to the tank? Going to try putting a clear line in place to see if anything is passing from the tank and what it looks like.
Any suggestions?
My thoughts:
Any suggestions?
