hello,i'm new at this ,hope i'm doing this right.<br /> i can't believe i did this, but i did. in the fall i drained lu on my 115johnson looper with intention of adding moly, but wanted to research the idea.this spring i forgot all about it. ran 3 miles up the lake before i realized it, stopped checked tightness of the upper plug, horror, had to run the 3miles back.pulled boat removed lower plug,small amount of really burnt, black ,stink 1\2 to 1 oz of oil. topped up fresh oil ,test ran, drained, found fuzz on magnets,and silvery pasty gooey on bottom of drain pan.replaced oil, ran tank of gas,drained ,more fuzz on magnets some silver flakes in the oil,i hear no noise or feel no roughness when i spin the prop.what do you think i may have damaged,how serious and should i pull apart the l.u. and replace something before it gets worse? i really appreciate any advice.here is a lesson for anyone,stick a note on your engine to remind yourself if you intend to put off an important job till the next season.<br />Thanks.....signed...idiot with a sore head from bangin it against the wall!@#$%^&
