Ran Yamaha v4 130hp out of oil
gdpalumbo
Hey everyone,
So I’ve had my 18’ Jason fish and ski for 15 years with a 1988 Yamaha 130hp V4 on it. It’s always ran fantastic for me. Yesterday I accidentally ran the motor out of oil. I was turning about 4,500 rpms when this happened. I heard the motor start to knock and immediately throttled back to neutral and the motor stalled out. I crank it over once for a second to make sure it wasn’t seized and it turned and still sounded like it has some compression. I feel like such and idiot because I have never had this happen. For some reason I got no alarm. I do have a Yamaha lcd marine meter that shows rpm that apparently goes blank when oil gets low and I saw this happening but didn’t know that’s what the gauge was going blank for....I thought there was a loose connection but now I know for the future. Do you guys think there’s major damage done? I’ll do a compression check later on.
My plan is to drain fuel from carbs, suck up a rich mixture into float bowls and spray into cylinders as well. I really hope I didn’t do damage. I’m fully capable of a full rebuild on this engine but the kit is 800-1,000$. Please let me know what you think. Thanks in advance.
harringtondav
There will be some damage, the question is how bad. 4500 rpm = 75 strokes/second under load w/o oil. You've nothing to loose by trying to start it and see what happens. I'd spray oil into the carbs while cranking to get some lube in the crank case/con rods. If it starts, good. If it runs without a lot of unusual noise, better.
I'd suspect some cylinder wall scoring and compression drop. Enough to render the motor useless? ....you will find out.
gdpalumbo
You think rod and crank bearings ok? So if I have decent compression numbers and I don’t hear anything do you think it will be ok? I know it’s hard to say...I would say after it started knocking it was probably 2-3!seconds before I yanked it back to neutral and it shut down.
