skunkedskippy
- Joined
- Apr 30, 2017
- 130
Random alarm - sometimes short chirps, sometimes solid for a few seconds. Only when in gear and at operating temp. The only patterns I noticed are that it often occurs just after I increase throttle. Also seems to occur more around 13-20 kts, and rarely above 23 kts (did not note the RPMs at these speeds).
If I unplug the coolant alarm sensor, the random alarm goes away. I replaced the sensor but alarm still sounds. Unplugged the new sensor and the alarm goes away.
Also bled the system (per service manual) which did not help. I feel like either I'm not bleeding properly, or there is a blockage in the housing where the sensor is mounted.
Here's what I know about my motor:
Mercruiser 5.7L serial# 0M009325
Closed cooling system with heat exchanger
Mercarb 2 barrel
Thunderbolt V ignition
Bravo 2 outdrive
Any help is appreciated.
![IMG_7224[1].JPG IMG_7224[1].JPG](https://forums.iboats.com/data/attachments/337/337686-a4397774894acd3960080919edb95f16.jpg)
Mercarb 2 barrel
Bravo 2 outdrive
