Went out on the lake today and had an interesting experience
After all my repairs and maintenance, my Chrysler 125 runs sweetly - get's up on plane quickly and the boat cruises at 35mph @ 3800 and seems happy to do that constantly.
If I push it to full throttle I'm doing 42mph @ 4200 rpm (which is still too low). However, every so often the engine just cuts out. It restarts rightaway and continues as if nothing happened. Only seems to happen when running flat out.
What do you think? Fuel blockage from something floating in the tank? It has new fuel hose and filters from end to end and a new pump diaphragm. Haven't had a chance to look into the tank to see if it's full of crap but I did put a bottle of dri-fuel in just in case. There is nothing obvious in the clear fuel filter I added.
The prop is the 'standard' 13*19 AL so I'm a little concerned that the boat isn't pulling at least the 4500 minimum for WOT. The foam is dry and the compression is 150# on all 4 cylinders.
