I am a new ranger owner, but not new to boats.
I am perplexed as to why the wiring is that way it is in this boat.
I have a 24 volt trolling motor. Both batts for the trolling motor are run in series to make 24 volts, but one of the batteries in the series has all the electronics that run the bilge, radio, and all the other crap hooked to it.
Then the starting battery has just the motor hooked to it.
I have always had all the electronics for any boat that I have owned hooked to the starting battery. That way it has a way of charging if I am out on the water for a long time.
I need full capacity from the trolling motor batts because I fish pro walleye events all year, so....
What are your guys thoughts on this. Should this be wired this way? or should I take all the accessories and put them on the starting batt?
BTW, it is grossly under powered as far as the batts go. Only group 27's for the trolling motor and a group 24 for the starting batt. and they are all walmart batteries. So first things first, have to get some AGM's in there.
