still trying to get my 73' 65hp evinrude running. Reasemble lower unit with new gears and all is well.
Seems when i fix something......something new goes wrong.
Been scanning the posts and have picked up alot of info but still cannot rectify my problem.
Have had the boat in and out of the lake for water tests but still having issues.
Latest........
Engine barely cranks and starter worm gear sticking in upright position.
I greased the gear and still sticks.
I pulled the plugs and engine cranks just fine and starter gear returns to normal position.
Noticed the safety nuetral switch has a white wire on the top. Also has a terminal on the bottom but no wire. Didnt find any loose wires.
Thought battery was low but since it cranks fine w/o plugs, i assume its ok.
Pls help.
thanks in advance,
Chris
Latest........
Pls help.
thanks in advance,
Chris
