Wide Open II
- Joined
- Jan 31, 2003
- 9
Now I'm really perplexed. While working on fixing a trim unit problem on my 1998 Optimax 150, I read in the manual that the fuse that protects the trim unit also protects the instruments. I checked the fuses on the side of the engine, but just to be sure, I turned the ignition switch to on to double check. The instruments worked. The cowling was off the port engine with the trim problem and when I turned the ignition switch, I could hear the fuel pump, (at least I think that's what I was hearing) run for a couple seconds. Just to completely double check, I turned the ignition switch on the starboard engine to verify instruments. The cowling was on that engine, and I didn't notice any noise from the pump. However, when I went back to the stern, I noticed a considerable amount of RAW GAS was coming from the vents and propeller exhaust on the "good" starboard engine. The port engine had no gas coming from it. Please tell me this is normal!!!! I mean about 1/2 cup of gas came out. I've washed it down, and no more now. I've never run these engines on muffs, only in the water, so I don't have a previous experience to validate this phenomenom. Cant find anything in the manual about it either. Help!!!<br /><br />Still trying to track down the trim problem too.<br /><br />Wide Open II
