"raw water&closed" cooling volvos
nikk
it looks like many have this problem i hope someone can answer mine when im below 3ooo rpm the engine temp sits at 160-170 when i run at full trottle it goes up to 200-210 until i slow down the temp goes back to 160-170 the motor i have is 1992 aq 131 fresh water and closed cooled also it looks like there is alot of air bubbles coming out the out drive also is there a pump in the out drive to suck up the water or is it just the impeller thats curculating water what would cause air bubbles would this have anything to do with the temp changes and would a higher octane lower motor temp..???
Dunaruna
Re: "raw water&closed" cooling volvos
What model outdrive do you have?
nikk
outdrive model 290 "1992"
rodbolt
hello<br /> when was the last time the raw water pump was rebuilt or replaced? is this boat used in saltwater? have you cleaned the heat exchanger ends? have you checked for clogged risers? usually clogged riser/manifold shows up by burning the rubber exhaust boot between the pipe and riser. and finally the oring at the bottom of the streering swivel tube. if it leaks it will suck air at planeing speed and cause heating problems. its a beast to change and most people here go to a thru hull scoop for a water intake. you outdrive has no water pump in it. in saltwater we also have some problem with the water neck at the top of the swivel tube start checking serviceing and eliminating and the problem will be cured :) <br />good luck and keep us posted
