Once engine is running warm at idle with choke open you want to see pretty much the same amount of water exiting the exhaust as what is going in. The exhaust is an open ended system with constant flow, the only cooling water that isn't continually exiting is what is in the engine block. Once the thermostat opens that water can exit and be replaced by incoming water supplied by the sea water pumpCurious on how much water I shoukd see coming out of my exhaust and prop while running on muffler. Ford 302...mc-1. I just changed the impeller and housing. Could someone post a vidio if possible
at idle, just about 7 GPM is running thru the system with all the restrictionsCurious on how much water I shoukd see coming out of my exhaust and prop while running on muffler. Ford 302...mc-1. I just changed the impeller and housing. Could someone post a vidio if possible
About this much this is an MC1, this guy has a lot of water pressure to the muffs so if you are on a well may be a bit lessCurious on how much water I shoukd see coming out of my exhaust and prop while running on muffler. Ford 302...mc-1. I just changed the impeller and housing. Could someone post a vidio if possible
I think that was a casing drain used on some MC-1's but not sure @Bondo may knowYa mine is pretty close to that..little less maybe. I see a solid stream coming from the lower unit on the right...I see that hole on mine but I believe it's plugged now that I see that...drill it out or what best
Ayuh,..... There's an idle relief port on each side,......Ya mine is pretty close to that..little less maybe. I see a solid stream coming from the lower unit on the right...I see that hole on mine but I believe it's plugged now that I see that...drill it out or what best
That's the drain for the front cavity of the drive lower housing. Yes, it must be clear, or the water in there will freeze and crack the housing. Poke, prod, anything to clear it. One some drives I've worked on I've had to drop the housing and also start clearing it from the top as well as poking and prodding from the bottom.What I meant is the tiny hole on the right side only
