raw water hook up for shamrock
ciliento
does anyone know how the plumbing goes for a 1976 shamrock ford 302 I am having difficult locating a diagram, I have pictures of my set up that I can email if you care to see if you can figure it out
Re: raw water hook up for shamrock
It Really Doesn't Matter if the motor is in a Shamrock,..... Or a Bayliner,.........<br /><br />We've got to know the Engine/Drive combination,+ Who Built It......... Not the Boat Manufacturer......
ciliento
Sorry about that, it is a Shamrock boat year 1976 with a 302 Ford engine, set up by Pleasurecraft Marine engines, it is raw water cooled. I am trying to find the way the alternator and the raw water pump and the plumbing goes from the raw water pump to the exhausst risers
snapperbait
There are 3 PCM marine engine manuals on this page (scroll down).. http://www.correctcraftfan.com/reference/ <br /><br />Those should get you the correct location for all the hoses, pump, alt, ect....<br /><br />BTW.. ciliento. Where at in FL?...
prockvoan
Solid boat,good set up.I ended up repowering with a FWC 351 on the Shamrock I had.I have some replacement decals if you need them.<br />As for as the raw water set up,exhaust mans and risers(which should be Osco's)are set up as any other raw water cooling systems.
