Salty Fresh
- Joined
- Aug 18, 2008
- 6
I have a 2000 7.4 Mercruiser Bravo 3 with a hot temper.
I searched all the old threads and happily found how to trouble shoot and finally the problem. The raw water pump impeller on the engine side was in 20+ pieces. Literally every fin was mauled off and ripped to bits.
I backwashed from the manifolds, disconnecting at the oil cooler, steering cooler, and flushed out a lot of small bits.
Assembling the jigsaw puzzle, I'm missing around 10 % of the rubber maybe less.
Yes, it had never been changed before and roughly 350hrs on the engine.
So the question is do I need to remove the manifolds and risers or can I assume the remaining bits passed out or will?
The missing pieces will be very small and I'm hopefull you guys will tell me the manifolds and risers passages are large enough.
I really don't want to remove them for a few reasons but if absolutely...
Also, do the fins on the impeller need to bend a certain direction or will they just flip the direction required?
I bought the kit not just the impeller.
Thanks for your replys
