Raw water pump casing
Wave34
My casing is not perfectly flat. The middle part is raised a bit.
I measure a difference varying from 0.005'' to 0.020''.
Is it supposed to be perfectly flat?
Is that wear and if so, when too much is too much?
It's on a Volvo 5.7Gi-D 2004
It should be flat but a 0.015 variance over full surface with rubber doesn't seem to be an issue. Hey @kenny nunez
cyclops222
Is the spinning impellor metal of a non metal part ?
I really would doubt that .015" is going to affect the pumping efficiency at all. That is nothing compared to the total volume of the pumping chamber. THat sealing O RING looks crumbly ?
Is the temperature of the engine O K ? That sealing O RING looks worn ? Is water running out of the pump casing ?
Wave34
Lay down a sheet of glass, get some wetsanding paper and flatten it as best you can.
the non even surface is inside of the pump body, so I don't see how I can reach there. Unless I don't understand what you try to explain...
Wave34
I found something.
(My impeller is made of rubber.)
For the last 6 years, I was changing my raw water pump impeller every two years using a Sierra brand unit. It always worked well, but not this time. I discovered that THIS new Sierra impeller was 1mm (0.04'') shorter than a brand new Volvo unit that I just bought to test.
My problem was that the pump was not priming itself, even using a bucket with 2 hoses to test directly at the RWP.
It should have pumped because I was feeding water from the Volvo rinse port, not the outdrive leg.
I put the Volvo impeller in, and it worked perfect the first time. So, those non OE impellers are made with a lousy tolerance I believe.
PS: Before buying the Volvo part, I changed the bearing seal and a new O-ring on the casing without improvement. The impeller was really the problem.
Grub54891
Ah yes. I assumed it was just warped a touch. Reguardless, I'm glad you found the issue.
