kwoolard
- Joined
- Feb 9, 2003
- 420
I own a 22' SportCraft with a 1974 888 Mercruiser that is driven by a Ford 302. My father-in-law previously owned this boat and had some overheating problems....not sure exactly what was causing it. However, along with having a water pump in the outdrive he installed a raw water pump that is belt driven. The raw water purmp picks up water from the hull (seacock and strainer). The water line from the outdrive and the water line from the hull or seacock "T" together and enter the raw water pump. From there the raw water pump feeds the circulating pump. So basically what I have is two water lines feeding the raw water pump...one pressurized from the stern drive pump and the other from the hull or seacock.<br /><br />Should I keep this set up or should I remove the water pump from the stern drive and just use the raw water pump or should I remove the raw water pump and just use the stern drive pump? <br /><br />My worry is that if I leave both pumps on, one might be working against one another and I will not get the proper water flow.<br /><br />I would think that two water supply lines would be more than enough to supply the cooling system for the motor.
