Hi
1995 four winns 5 litre ford I/O
Have not been able to use since September 2022 health issues. When I put it away and ran muffs to change oil I noticed drips from the belt driven sea water pump, One person said because hose turned on too high and it will be okay in the water??
Am hoping that is the case?
What are the parts # for:
the two sealed bearings that are stainless steel
the shaft seal
the O ring
I am really stuck here as we do not have reputable repair here, and my boat is really showroom condition.
I think the raw water pump is a 3857794, V belt driven, has rubber impeller behind the hose ports.
if it is dripping I have yet to see as not in water.....is it sucking air too?
Hoping someone has diagram and part numbers or experience as I am stuck.
Thanks
ron3033
the shaft seal
the O ring
Thanks
ron3033
