Re: rd-24 johnson wiring
thanks for that. a big problem I have is how do I turn the engine off? I havent started this outboard yet and uber he cover is 2 wires that go nowhere and the 2 main battery cables
First you say it is pull start, then you say (and show) that it has wires coming out of it. Manual start motors have no wires coming out. So...either you have an electric start motor, or you have a manual start motor that somebody has modified. Furthermore, if it is an electric start motor, those wires you picture are not what Johnson put in at the factory.
Bottom line: We don't have any idea what they go to. You will have to look and see where they go and figure it out from there.
Refer to the diagram: The ignition switch electrically connects the two black wires together to stop the motor.
