Hello guys, I finally got this motor torn down, (In the sep 20 post of the video on the rubbing noise), I was able to get both crank bearing caps off, the bottom cap on the outside had a lot of what looks like white grease, I removed the cap and everything was clean inside and the bearing felt good and was pressed on. The top cap it was clean on the out side and clean on the inside the bearing was loose and slipped off the crank just using my hand, the bearing feels good but is not pressed onto the crank, the bearing fits into the cap like a close fit but does slide in easily. I don't know if that could cause the noise even though I know it should not be that way as it should be a press fit. I know that both surfaces are hardened and was wondering which would go first the inner bearing surface or the outer crank surface? Both surface areas are smooth and no evidence of bluing or heat. The whole assembly spins easily, I did check for piston/rod play and I do have some when I press on top of the piston and feel a small knock maybe two to four thousands and all are about the same. The last time I had it out down the shore a week before Sandy the noise seemed to be almost constant now at all rpms when before it was mostly at 18oo rpms. Any Ideas? I hope Chris 1956 got lucky from Sandy, me in sea isle had no damage. Thanks Buz
