RE: 58 johnson 35hp
tim thompson
RE: 58 johnson 35hp
Thanks for the help. I read through info and then went back out and decided to tap on solonoid cause no sound when turn on key and no start.I turned key and if fired. Messed around and fuel seems to be suppling. How much water should be expelled out of the impeller exit.It doesn't pour but squirt/spray back. How do you know it is adequately cooling other than touch?
