Re: converting 2 line pressure to 1 line fuel pump
Don Tauer
2 Line tanks. The tank I have does not have the pump by the handle. the connection has three stubs, one solid and two that are open, then above them there are two small pins one stationary and the other lets the pressure out. Have researched and that tank was used until 1959. data on those tanks is very hard to locate.
freddyray21
it is a pressure tank. One of the hoses takes air from the motor and pressurizes the tank. The fuel then comes out the other line to the carb.
F_R
Say what???? Never heard of a pressure tank without the primer. The three stubs sounds good, but then you lost me again with the small pins. What kind of outlaw tank is that anyway?
Are you wanting to know how to convert the motor?
