Re:Frustrated from a Leak
Dmoose
I have a 1990 20.5 carrera elite Im at the river and I have to keep hitting the bilge I cant find the leak I had the plates sealed they said the bellows were good and the plug and hole are good I cant find any cracks I ran the motor in the lake with the hatch open and cant find any cooling leaks it will take on water beached my friends say its splash from the rear vents but Its to much water anyone have a clue thanks David
alden135
Re: Re:Frustrated from a Leak
First thing I'd be doing is putting some water in the bilge while it's on the trailer. Don't add to much weight when doing this. This will help rule out for certain that you don't have a crack/hole in the hull or the drain is in fact leaking.
