re jetting after rebuilding
JJB
I wanted to know if you should re jet your carbs after rebuilding a 2000 175 johnson . .30 over ?? crowely recomended .0002 up on the jets
Benny1963
Re: re jetting after rebuilding
i would run it stock and watch the plugs .
you can also push your primer selinoid and if it stumbles you may be all right for a quick check,there are some other people that will chime in .
Bennyb
Dhadley
Who is backing the warranty? If it's Crowley then do it. If they built it and are warranting it then they should have already done it.
The bottom line is - if they are backing the warranty it really doesn't matter what anyone else thinks. Unless you don't want the warranty.........
Faztbullet
Any engine I build over .030 gets up sized jets!! .020 can run stock jets as long as no head work(shaved) or swap was done (higher compression ratio).I have see as much as a 500 rpm GAIN by upjetting and have seen no gain too...
