Re Johnson 130 manual
JC1933
Good evening all,<br /><br />I ordered a manual for my engin which is a 1995 130 hp model, Was there anny changes maid between 1994 and 1995 in these engins? The reason i ask is because the manual i was sent is a 1994 book that covers 125 hp to 300 hp, it is a OMC manual.<br />thanks. J,C, :confused:
Dhadley
Re: Re Johnson 130 manual
The 130's should be the same in those 2 years. Are you looking at anything in particular?<br /><br />Whats the model number of your motor?
JC1933
Hi Dh,<br /><br />The model # is J130TLEOA<br />Carbs seem to be difrent the manual shows a carb with an idle mixture ajustable needle,my carbs have an orifice in this location.<br />Book also shows a slow speed needle and spring in the throttle body, which i can not finde on mine, this is what got me thinking that there may have been some changes and i might have the wrong manual. Thanks a lot for your time. J,C,
Dhadley
The 95 A models should have the 2 small fixed jets and an adjustable needle in the top of the carb body. Yours doesnt have that?
JC1933
No my carbs only have the two fixed jets, no needle in the top of carb body. J,C,
Dhadley
Does it have the "thumbscrew" air box (silencer)?
JC1933
Sorry for the late reply,i was at the lake.<br /><br /> Yes it has the thumbscrews on the air box.<br /> thanks . J,C,
Dhadley
Interesting. Every carb assy that uses the thumbscrew air box has an adjustment screw. Are you positive it isn't there? It should be at about 11 o'clock just outside the venturi. It may not stick out, you may have to look close. If it isn't there we'll have to figure out what carbs you do have.
JC1933
Dhadley thank you so verry mutch for your help.<br /><br /> Yes it's there at 11 o'clock i thought this was a mounting screw as it has a large head.<br />now my manual states that this motor has two dual throat carbs,<br />My motor has four carbs thet have the same number which is 436604 on top of carb,the two top carbs have sticker on the side cover plate with 43554<br /> 08LS<br /> Mexico<br />My manual also shows a slow speed needle in the throttle body which i doo not have, this i think prooves that i have the wrong manual. Thanks again<br /> J,C,
Dhadley
You do actually have 2 dual throat carb assemblies. Carb assemblies . They really confued everyone with this one. You have 4 carb bodies (1 throat each) and 2 throttle bodies (2 throats each). Each carb assembly consists of 1 throttle body and 2 carb bodys.<br /><br />If you think thats confusing, consider a V6. It has 4 carb assemblies. 2 dual throat assemblies (just like yours) and 2 single throat assemblies.
JC1933
Finley i understand the diference between 2 dual throat carb assemblies, and carb bodies.<br /> <br /> I cleaned the carbs today complete with new kits<br /> this is where i noticed that my throtle bodies dont have the slow speed needle like in the manual they are on the top left of each carb like you mentioned, should i get a 1995 manual to replace this 1994 in case there is other changes from 94 to 95. <br /> I realy appreshiat your assistance, thanks. J,C, ;) ;)
Dhadley
It may be a good idea. You'd have to go thru the entire parts lists on both years to verify any tiny differences. It may well be the carbs and linkage only. The ignition is the same as well as the block and all internals. <br /><br />Isnt that the way it always is -- the one thing you need to look at may well be the only difference.....
JC1933
Thanks a lot D, will let you know how it idles when i take it out next, have a nice day, J,C,
