Re: please help an idiot out 1986 force 125
lquested
ok frank thanks for kicking me on the shift forrk screw i took it like a man. i thought that was the oil drain plug. but i think it is an allen head bolt at the bottom... but i got the oil changed too..lol
thanks, never saw the water comming out from the lower unit bolts before.. why is water comming from 3 out of 7 bolts any way.. i guess i did a good job thanks again..
maxum247
Did you put the pump together in this order starting with the water pump gasket on top of the gear case housing cover then the back plate next impeller then the waterpump body and finally the lower water tube seal?
