imported_walleyeman
- Joined
- Jul 21, 2006
- 21
What should come first? Do you keep purchasing props until you can reach the max WOT RPM range or do you estimate the proper pitch and adjust the height of the motor to hit the max RPM range? Which comes first?
I have been reading quite a bit on here and have learned many things. Thanks to all who are knowledgable and take the time to share. In my situation I have a Lund 1600 Pro-sport with 2007 90hp E-tec. It is on its lowest motor heght setting (motor sitting on transom) and it is propped with a 13.25(I think) x 17 OEM Alum. Prop. It is able to climb to just about 5100 rpms at wot with a full tank of fuel and two adults on board. ( 90etecs are to be run at 4500-5500 rpm's) Its wot speed is 40mph (speedometer) and if I recall it is 37 mph by gps reading. What should I do?
Should I re-prop to a 13.25x15 and probably bump the rpm's up by 200 or should I keep the current prop and raise the motor one notch. (Note: No current problems with ventilation/cavitation at current setting, full trim range is usable)
