Re: selva 90 montecarlo starting problem.
I have a selva 90 montecarlo outboard which i am told is practically a re-badged yamaha autolube. This has been very reliable and then one day it decided not to start. The starter motor turns over but only just, once and then i have to recrank it , but it turns over nicely once i take out the spark plugs. I beleive having taken the starter motor apart that it is fine and i have tried a couple of batteries both of which i know to be ok. i have tried running a cable straight to the starter motor from the battery and this makes no difference as does running a cable from the earth of the batttery directly on to the engine block earth! I was wondering if anyone knows of anything else i might try and any info would be gratefully received.
