Re: Small hub prop, Sealed on large hub
dan02gt
On something like a 5.7 MPI 300 HP engine/B1 with thru hub exhaust, will running a small diameter prop with one of these seal rings increase back pressure on the engine to the point that there is any problems with either exhaust or cooling water flow?
Thanks
Gil
I can't see a blow out ring causing you any problems on that setup. The small barrel prop is only about a 1/2? difference in diameter and I can't see that adding much exhaust restriction at all. Guys run the small barrel Trophy Pluses all the time on 250HP outboards with no problems.
