Re: Step By Step Impeller Change
wickware
Re: 1974 Chrysler 35 hp
Quote:
Originally Posted by SeaForce1962 (from post above)
I followed the instructions above and changed mine, first time, take your time, biggest problem will be making sure you keep your forward/Neu/reverse/. correctly lined up. Take your time, if I did it anybody can,
SeaForce
My Questions/Concerns:
1. If the gear-shift-rod is disconnected at the cotter pin vs adjusting linkage (on the 1970 35HP Chrysler), readjusting the forward, neutral and reverse should not be necessary, Right?
2. It was tight but I was able to disconnect in a small leg opening after disconnecting some linkage at the motor (attached).
3. Was this the best option or was there another way to get to the cotter pin?
4. Maintaining the boat, motor, trailer and etc (off-season) and working firewood over the years has always seemed strange and ?old now?, But Fun!
Thanks for comments in advance.
JOW
dkonrai
i used a pair of needle nose pliers (long snout). the hardest part was bending the cotter pin.
