Another task I'm doing is rewiring and organizing the connections in the center console (almost 80% progress now). I'm doing this after all the mess due to the gas and water tanks replacement.<br /><br />I will post some pictures soon.<br /><br />In the meantime I have some wiring color code questions.<br /><br />I have investigated a bit (other postings on iboats and other forums) about the ignition switch connections.<br /><br />Could you please verify if I'm correct with my harness coming from the engine to the ignition switch (OMC, 225HP 1994).<br /><br />Also, could you please provide info on those cables I don't know:<br /><br />1) Black with yellow strip: ignition module kill (goes to M post)<br /><br />2) Another black, no strip: ?????? (is this a ground to kill the ignition module?) (goes to other M post???)<br /><br />3) Red with purple strip: +12V feed (goes to B post)<br /><br />4) Tan : goes to horn (overtemperature signal)<br /><br />5) Purple: to horn (from VRO alarms??)<br /><br />6) Gray: pulse signal from engine, goes to tachometer<br /><br />7) Yellow with red strip: this is the feed to the starter solenoid, so it goes to the S post)<br /><br />8) Purple with white strip: this is the feed to the choke (it goes to C post)<br /><br /><br />Another question: could you please indicate me the purpose/connection of each cable from the trim/tilt harness? I have a single bundle with these cables:<br /><br />a) White with tan strip<br />b) Green with white strip<br />c) Red with white strip<br />d) Lite blue with white strip<br />e) Black with tan strip<br /><br /><br />Thanks again !
