re wiring
rdny041285
Does anyone have any idea how much it would cost to re wire a 24' 8 " 1983 wellcraft?
Re: re wiring
Ayuh,... That's a Much Too generic Question to Answer...
Rewire What,..?? The Motor,..?? the Helm,..??
Are you talking the Whole Job,..?? Just Parts,..??
rdny041285
Re: re wiring
well, the gauges dont work, the lights in the cabin dont work and some other stuff doesnt work. motor is fine though so pretty much just everything in the boat...
Re: re wiring
Ayuh,... Is this something you plan to do Yourself,..??
If so,...
There's a generic boat wiring diagram on the top of this forum,....
Grab your Testlight,+ Multimeter,+ start where you Do have power,+ See where you Don't....
For all We know,... You might have a couple of Bad Bulbs, or Bad Grounds...
rdny041285
Re: re wiring
i was actually thinking about paying a proffessional....id probably kill myself doing it....but i need someone to clear out the big ball of wires under my dashboard lol.
Silvertip
Re: re wiring
Haven't seen anyone electrocuted from 12 volts lately. Burned -- yes! But not electrocuted.
Re: re wiring
Ayuh,...
I gotta believe you're lookin' at atleast a Day,...
Maybe 2,...
Maybe only an Hour...
Times the going Shop Rate in your area...
legoman67
Re: re wiring
I rewired my 29ft myself, started at the power(stern) and worked forward. I found much of the wire was still reusable, just added new ends. Make sure you have lots of connectors and ends before you start. Also a good wire stripper/crimper, and afew roles of electrical tape(will become your best friend). I only bought 200ft of additional wire and was able to rewire my entire boat.
Took me 3 days. Its not hard work, and i wasnt going full blast. I actually find it rewarding, stringing all the wires and then having things work when its done.
The trick is to get from point A- B in the shortest amount of space, but without the wire showing. When i pulled out all my old wire i made sure to leave 1 or 2 going through each tunnel or pipe, that way i could pull more through. As long as you make sure to never have no wires going through a certain point you can almost always get more through relativly easily.
12 volts isnt deadly, it will just keep you awake :p
Also the service manual for your engine should tell you how to wire up the guages. What sort of engine do you have? I have mercs and wiring the engines was the easiest part, just added extentions to the cannon plug, labeled which wire was what number, then strung them to the bridge, and played connect the dots using the service manual as a guide. :)
kcs1211
Re: re wiring
I just had my 21ft Glasply rewired. Cost $400 in labor and was well worth it. Parts got expensive because I put in a 8 position waterproof switchboard and new Battery switch, all new gauges etc. But Im VERY happy with the results.
I could have done it myself but I hate electrical and don't have the time, so to me $400 was reasonable.
rdny041285
Re: re wiring
thanks for all the input guys. will definately help in my decision. 400 seems reasonable especially with my lack of experience in electrical work.
