ready to re -assemble
bobhol
I am ready to put on the new bellows and shift cable .since I have the bellhousing(helmet) in my hand I thought I would thread the shift cable housing on it first then slide the shift cable bellows on it.Water pump hose is on the transom connection . Glue and clamp the drive bellows to the transom side as well as the exhaust bellows. Then connect the helmet end of the water pump hose and gear lube hose....push helmet forward and connect drive bellows and exhaust bellows. slide shift cable bellows to transom connection and tighten all clamps (in their correct position). slide shift cable thru housing and hook up both ends....does this sound like a plan or am I missing something....Everything has gone good till now except for breaking the nipple off the oil lube monitor hose connection. It has been replaced...I am nervous but confident I can get this done ...:redface: maybe...hopefully...thanks Bob
zbnutcase
Re: ready to re -assemble
You pretty much got it, Loctite the hinge pin bolts, and do you have the driver tool for u-joint bellows retaining ring?
bobhol
No driver tool as such but I have a pvc fitting that should do the job ...and power tuner as don suggested to lube it up .. any other suggestions? ...:)thanks Bob
