Re: Really Confused
Pic. #1, This is the cruise control, and full throttle control rod. You can loosen the brass keeper as the first step.
Pic. #2, This is the throttle cam follwer. The groove in the rubber roller is from wear, it won't hurt any thing. The loose play in the throttle rod link in the same pic. is normal, and also won't hurt anything.
Pic. #3 This link control's the carb. throttle plate, This will be your first adjustment. Advance the throttle untill the rubber roller is centered with the mark "marks" on the brass throttle came. The carb. plate should just start to open. If it open's early, or late, loosen the set screw on the throole plate of the carb, and adjust the link so that the rubber roller is in sync. That's it for the front part of the linkage.
Now rotate the throttle to full advance, and hold it there. you can do this with the remote control if it is hooked up.Now go back to the brass keeper in pic. #1. Push the throttle rod all the way forward until it stop's. This will open the carb. plate all the way. Push the brass keeper back against the throttle arm, and lock it with the set screw. That is it for the linkage adjustment's. There is no timing adjustment on this engine. That is taken care of when the point's are set.
Pic. #4 That link lock's out the rewind starter when the throttle is advanced to far. It is a safety feature.
