i am pretty sure i have a leaky rear main seal but i would like some feedback here.. 1982 larson omc 25'. bought a new motor this winter and rebuilt it. new crank, bearings, rings ect... it runs like a top. .however it leaks oil. if i am looking at the motor its on the left side... oil is shooting out pretty good. every 2 hours of cruising i leak out about a half quart... ( it looks like a hell of a lot more). the higher the rpm's the more it leaks. if i put my hand under the motor by the starter area i can see the drops of oil hitting my hand. i tried some stop leak but it did nothing. i have been using the boat for a few months and it has not got worse all season.. is there anything else it could be. before i pull the motor i wonder if there is anything else i can check. the flywheel turning is causing the oil to shoot out pretty good in the engine compartment...
