What are you doing up so early in the morning?
Rear engine mounts . . . do you mean the bolts/spring washers, etc that holds the engine to the transom assembly?
Ayuh,.... If ya can get a straight shot on it, donno why it wouldn't work,....
Bt Doc made a rear mount press outa threaded rod, 'n pieces of pipe,...
picture of it 'round here somewhere...
Maybe a big c-clap to press it out. . .
You can burn em out too!!
But once the rubber is removed its easier to drive the ring and shell out. Tried the C clamp route but you MUST have it prefectly straight so I made this. Its relieved to self locate.
