Reasonable compression numbers for AQ131A?
film842
Although I tested my engine two years ago, I failed to write the compression test results down and so want to do it again.
It seems to me that they ranged in the 140 - 150 range, but am not sure.
Can anyone advise me on what is good and what is bad? Thanks.
jerryjerry05
Re: Reasonable compression numbers for AQ131A?
The book???? calls for 140-150.
But your guage and mine might read differently.A 10$ guage might not read as good as a $100 set??
Look for results that are the same.
Like all at 120 or 125 etc.
5-10#difference is ok any more than 10#difference there is a problem.
film842
Thanks. I did wonder about the possible difference in guages. Well, will be interesting to see what I get.
Don S
PS: The "Book" if you download it, calls for 142 to 170.
