rebuild 135 johnny ....
coolbikeguy
can i tear down and rebuild a 74' 135hp johnson without having any " special factory tools " i have plenty of hand tools, standard, metric, pullers, gauges, etc ...
D
DJ
Guest
Re: rebuild 135 johnny ....
Sure you can. The maching of any parts will need to be done by a pro but the rest of it is pretty basic.
Words of advice: GET a manual. An OEM one.
Fl_Richard
Most likely you'll be fine. You may need aspecialized tool or wheel puller fo rthe flywheel but the money you'll be saving can easily cover the cost of a speciality tool. (I didnt need any special tools for the rebuild of my 1995 150)
The manual will call for a few special tools but they are usually not needed or can be worked around.
Good luck!!
Rich
coolbikeguy
ive got the factory service and parts manuals. and there is a local guy that does machine work on boat motors ( boring etc. ) so i think i've got that covered too.
coolbikeguy
im sure between the pullers myself, my step dad and friends have i will be able to come up with something to get the flywheel off.
currently the boat has a 115hp chrysler on it and im going to see a guy tomorrow eve that really knows his stuff about these motors to see if its worth building and if not .... ill be doing the 135 johnson i have. the bonus of the johnny is that it has tilt and trim although the trim motor is totally shot and missing parts ( cap is off ) thanks guys, scott
coolbikeguy
does anyone offer a rebuild kit with the usual replacement parts ... piston and rings, gasket set, water pump parts, etc ?? a full kit is what im asking about.
