I posted a thread earlier on a rebuild I was contemplating. (http://forums.iboats.com/showthread.php?t=275576&highlight=E75ERLCSA)
I got the rebuild done and put it on the water for the first time this evening. Ran like a champ for the first 3000RPM hour and then did the same for the 4000RPM hour. Bumped it to WOT occasionally as recommended during the second hour and it turned 5600 or a little better without a hitch. The Boyesen reeds (or the complete rebuild and link and synch
) made the throttle response better than it's ever been.
Thanks to everybody for the advice during the project and great past posts - used "search" quite a bit when I had questions and found a lot of great info that made it a lot easier - the write up on setting timing advance without having to run the motor, the tip on heating the lower main bearing to get it on the crank easier, and a few others.
I'm looking forward to getting back on the river this weekend an finishing out the break in process.
Thanks again!
Branden
Thanks again!
Branden
