Rebuild older VRO2 pump?
Lowranger
'89 Johnson 70. I really like the fact that this pump runs leaner @ trolling speeds while the newer OMS pumps run closer to 60:1. Repair kits are available for both the air-motor and the fuel pump for about $40.00 -vs- $360.00 for OMS. Will these 2 kits restore the unit or does the oil component need renewal as well? There is no mention of an oil pump kit.
DHPMARINE
Re: Rebuild older VRO2 pump?
You can't rebuild the complete pump,and because of it's age,you would really be trying a patch.On a tire,it goes flat again.If the pump doesn't pump oil,price pistons and cylinders.I also like the pump features,and would replace it.<br /><br />DHP
Crossflow235
Check out Ishopmarine.com<br /><br /><br />New OMS pump Part # BMC-5004559 240.31<br /><br />This includes the kit to update 3 wire to newer 4 wire version, and all fittings and hoses.<br /><br />Just rebuilt my 235 this last fall and deciced to replace old VRO before I take it out this spring.<br />Pump was working but was showing signs of minor leakage. New OMS @ 240 is (Cheap insurance if you dont like pre-mixing).
umblecumbuz
Premixing's free.<br />And accurate.<br />And gives complete peace of mind.<br /><br />Maybe I'm biased!
