Hi - I have a 1974 Mercury 850. I recently had the entire block overhauled (new pistons, rings, bearings, etc.). I also bought a new CDI switchbox, rectifier, plugs and plug wires. The boat fired right up and idled for about 8 hours with no problems at all. I dropped it in the water last week and ran it for about 30 minutes. Everything ran great. I went to idle and then turned the engine off via the key as I would normally do. After that, the engine would not fire again, but turned over just fine. I am showing extremely weak spark now, and sometimes none at all. Does anyone know what could have happened? I hate to go and drop another $200 on a new switchbox, especially if A) that is not the problem or B) the problem that caused the first box to fail threatens the new box - whereby I'll be back in this same position. The wiring harness, both interior and exterior are in visibly bad shape. The insulation is cracking off in many places. I checked the voltage on the white wire out of the switchbox on cranking and I only get 6 volts, and this is even after I wired the box (white/red wire) directly to the battery (thereby avoiding the wiring harness completely). Any ideas?
Question - Can the wiring harnesses be "rebuilt" using regular hardware store wire? How do I get the plug ends off to access the connection points? Does anyone think the harness may not be the culprit here? Could the box get fried by a bad wiring harness? With new wires, will the voltage come back up or will I have to replace more parts?
