Re: Rebuilding/Cleaning a carburator
A manual , is the first thing you need to get, preferrably OEM.
Thoroughly soak , and clean all passages , bowl etc. etc. etc.
If you have plastic carbs, be carefull with the carb cleaner.
Blow out with compressed air, cleanliness, is the most important thing.
Spray can be used, along with the soaking, but they have to be disassembled, to be cleaned correctly.
Simply spraying cleaner into throats, doesn't get'er done.
Install rebuild kits, and do a link and sync.
It's not as critical, in this post, but you need to post your motor info.
ie: make, year, model , etc. etc.
KYHunter
