Bt Doctur
- Joined
- Aug 29, 2004
- 19,477
These have been known to shear the oil pump drive after a rebuild. The reason is the shaft is not lined up with the dist.Install oil pump loosely and install dist in block. Align pump to shaft and then tighten oil pump body bolts.
This should assure alignment of the oil pump shaft into the dist and keep it straight.
