I'm working on my old powerhead, it's a 72 mercury 1150, I had bought 3 new pistons, all new rings, gasket kit, but I didn't pull the exhaust plate till it was too late and I found a crack in one of the exhaust ports, so I got a used powerhead on ebay but I want to fix up the old one, so I had a welder weld the crack, bored one cylinder, honed the rest, got a new exhaust tuner plate I think it's called, now all that's left is too do a little porting on the weld and clean up the engine for reassembly.
what's the best way to clean up the old pistons and exhaust cover plates, I've got a small sandblaster, I tried it on the scored piston that I'm replacing and it worked great, was thinking of doing them all and then sanding them with fine sandpaper, I've got a little steamcleaner that I'm going to try but I kinda doubt it will do much, thanks, Jason
