2stroke1971
- Joined
- Nov 8, 2009
- 210
Ive got an old Steury skiff, its a 1972 fiberglass 15 footer. The front seat in the nose had been sagging, so I rebuilt that one already..the wood under the fiberglass had decayed. That went well.
I planned to do the same to the middle bench...I was going open it up, scoop out the rotted wood, and then build up the insides of the sides with some marine grade plywood, and then I wanted to make a storage area inside the bench and I was going to make part of the top open on a hinge for access...
However...I cut the top off, scraped away the dead wood, and there are 2 large blocks of some sort of styrofoam in there!...something tells me I DONT want to remove that to make a storage area...am I right? Is that for bouyancy? If I remove it, would that damage the boats handling, etc?
I guess if I have to, I will just leave it there, get some new wood between it and the outer fiberglass on the sides, and then replace the top as a solid piece...
Thanks in advance for any info!
